Originally Posted by Z-linkCobra
Depending on availability of small block fords in Belgium a stock cast block can be had for as little as 50 bucks. Add some machine work money for a cylinder bore, line bore and cleaning and you got 300 to 400 bucks. an aluminum block is going to run you somewhere in the 5000 to 7000 range.
I've looked it up and the weight difference of a cast iron engine with aluminum heads and a full aluminum engine isn't much.(weight-price ratio)
5000-7000 is the price I would pay for a decent engine
I want 350 hp minimum
I'm thinking of ordering it in the USA .
I was looking at all different crate engines .
But for a person with no mechanical background it's hard to see what's the
Best choice.
Greetings
