Originally Posted by vatdevil
Wayyyy more open space than our local autocross courses. Would you be willing to share spring rates?
Spring rates won't help because I have different motion ratio's than other Cobra's. The wheel rates are now 150 lb/" front and 180 lb/" rear, you can use these numbers to work backwards just divide these rates by your motion ratio squared to calculate the required spring rate. Front bar is 1.25 ID 1.00 ID with a 10" arm, rear bar is .625 solid with an 11" arm.
