Originally Posted by Large Arbor
This may be a silly question but I am set to do my first oil change on the cobra. Will all the oil drain from the oil cooler when I drain it to the pan or is there any other connections I should brake loose?
Phil
Hey Phil,
No, the oil will not drain from the front hoses and cooler if just the pan plug is removed.
I did a complete draining
once. I removed the oil pan plug, removed the oil cooler, and drained the hoses. It was a nuisance and messy.
My capacity is about 11 quarts with Aviaid pan, large filter, hoses and cooler. Removing just the oil pan plug and changing the filter leaves less than 1 qt. of used oil left in my system. I can live with that. Now......if we're talking kidney dialysis, I'd opt for the complete flush.
David
