Old 03-26-2014, 10:05 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Alcohol will produce more horsepower if you have the right components. Ethanol or methanol is a higher octane. Hence forth you need more timing, higher compression and more fuel.
If I remember correctly the ratio is about 40% higher or more for methanol. About another 6 to 8 degrees of timing and 2 points or more compression needed. I would assume ethanol is about the same.
" If it wont break em loose in 3rd gear, it aint enough power "
