03-26-2014, 11:29 AM
AR
Cscobra - There must be a lot of variation in these bows if you didn't have to cut the windshield bow to miss the clips. I had to cut about an inch off both of mine. I think I'm going to be cutting close to 2 to 2-1/2 inches out of my back bow before all is done. I have 1-1/2 inches cut out now but it's no where close to fitting yet. Part of that could be differences in where we located the lift-a-dot tabs on the top hem. Mine is pretty snug at the snap right at the outside corners and I wish I had moved it out another 1/4 to 3/8 inch.
Since I installed the transmission shifter spacer from ERA I haven't had any problems with it kicking out of gear. But I might still check into that Tiger boot as the ERA one is pretty thick.
Thanks
Dan
