Thread: Bad Starter
Old 03-29-2014, 01:35 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Well after a day and 1/2 of screwing with it, my technical more skilled older brother came over and I pulled the starter again and out of the car it would engage, but would only once in the car. So we pulled the cover / cap off of the solenoid on the starter and noticed when taking apart a loose screw on the solenoid cap. We pulled it apart and could see where it was arcing to the case. After cleaning / filing some contacts on the solenoid, we tested it and it worked outside the car. We put it back in the car and it worked. Has started several times. I let it warm up and tried it and it worked fine. I think for safety reasons I will buy a backup and put it in the trunk. At least I know what the problem is now.
