Old 03-30-2014, 07:02 PM
Barry_R Barry_R is offline
Test fit the windage tray. Don't be surprised if the front bolt holes that go into the timing cover are not even close. It appears that Aviad welds the front "u" to the rest of the tray as a separate part and then grinds them smooth. After I fix them so everything fits I will glue a gasket to each side of the tray. Then its gray RTV on each end for assembly - a super thin layer like a coat of paint. The pans don't leak then - until they loosen up. Studs and serrated head nuts help....after you tighten them. I've been known to accidentally get a little silicone on the threads...
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
