Originally Posted by strictlypersonl
There should be a large ground cable from the engine to the chassis or battery negative somewhere. If the battery is mounted in the engine compartment, we might run a ground directly between the battery negative and the block.
My battery negative post cable is bolted to the engine block and the black wire from near the starter relay in Patrick's post is bolted to the engine also. There weren't any other grounding straps in the wiring kit. I have grounds to the frame at the front X-member, behind the dash, tailights, headlights (I think). I guess I will pick up a strap and secure between the engine/trans and the frame somewhere.
