Originally Posted by Z-linkCobra
Doesn't sound fuel related to me sounds electrical. Check your grounds. Check your coil.
Cap and rotor? check and make sure the coil wire is good and not grounding out somewhere. Its just going to be a process of elimination. Electrical problems can sometimes be tricky as hell.
Looks like Z was on the right track. Seems certain now that either the dist cap, coil wire or coil is the part we need to replace.
Craig
