Old 04-04-2014, 03:44 AM
renovationinnov's Avatar
renovationinnov renovationinnov is offline
Cobra Make, Engine: venom motorsports /ls1 auto
demis
drive way should be drilled & dowelled so the added concrete is attached by resin between the slabs
carport can be skim coated by 50mm concrete if height allows it
shed slab ... start again will be cheaper & use old slab as base for new slab
as I cant see you areas this might help
rob
not all your babies are your children
