PSB
Just my usual 2 cents worth! DVSF II (?) we had an electrical engineer/ Professor from U.O.M.- Yep that place up North, give us a 101 class in wiring our kits. HE said the "frame" should never be used as the primary ground. The engine / tranny should always be primary, (Something about rotating parts) then a ground to the frame. Something about OHM's and Resistance I didn't understand but I did comprehend his lesson.
Thought "Wreckerboy" was there for that little meeting??
But. kudo's to you, sounds like your solution worked.
DV
