Old 04-06-2014, 04:02 PM
427fast 427fast is offline
Cobra Make, Engine: Backdraft
Default HELP needed with my backdraft cobra!!!
I drag race my backdraft cobra and I have a serious problem with the rear differential getting loose and breaking the grade 8 lower bolt that holds it in place. When it breaks we have to use a point chisel to remove the broke bolt. I am looking at the solid mounts that backdraft sells and going to switch them out to solid. I am afraid to use lock tite cause then I won't be able to remove the broke bolt. I have been tighting the bolts every time I race but it is not enough. Please I need some advise here. Thank you
