Use Loctite. Loctite is easily removable by heating to 500F. If you need to remove just use a propane torch for 45 seconds on the bolt and it will melt the loctite. The only time loctite has the ability to break a bolt is if it is .25" or smaller. If you are concerned use loctite 242 as it is removable with hand tools.
