Old 04-09-2014, 03:53 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
Default Will a '69 timing cover fit a '88 block
I have what I think is a 1988 351W block. D9AE-6015-ED 14 Build code 8F22. What I think this means is
Block casting D9AE = 1979, Ford, Engine
6015 = Block
ED = revision
14 = unknown
8F22 - pour date = 8 year, June 22. Since the design was 1979, the 8 means its a 1988, right?
I want to switch this to a passenger side water pump inlet. I think the only year 351W that had a passenger side inlet was 1969. So, does a 1969 timing cover fit a 1988 block? I know that I will need to change my timing pointer and marks on the balancer, but will it fit?
Second question, if the timing cover won't fit, will the electric water pumps work with any timing cover? I can get an electric pump with a passenger or driver side intake. The pump doesn't state which year timing cover/engine - it just says SBF. Summit Clicky
