  #25 (permalink)
Old 04-11-2014, 05:44 PM
CBattaglia's Avatar
CBattaglia CBattaglia is offline
Cobra Make, Engine: Gary Edwards Racing 460
Originally Posted by mnm99 View Post
Can someone else confirm this also...As for emissions that is determined by the year of the motor." As long as your block is pre 73' you are good to go." That makes it even that much harder. Does a crate motor qualify with no smog test?
Call this number 845 691 7686. It the number for the NYS examination facility. They are the ones that determine that the car is good to go and they supply the official VIN. They will give you the info you need right from the horses mouth. You also need a weight certificate.
Pm me if you need more info I have a folder of all of this stuff I can dig thru it and give you any details. I have dot lense numbers for you too when you fill out the forms.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
