Old 04-12-2014, 08:04 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
I have the 9" rear with adjustable tubular arms. My opinion is it is the only way to go so you can set your rear axle tracking accurately. My rear axle measurements are 55 3/8" axle flange to axle flange, or 56" rotor surface to rotor surface. For the rear I have 10" wheels with 295 tires with 5 1/8" back spacing. The outside bulge of the tire lines up exactly with the center fender lip. Bigger tires may likely stick out. 5 1/8" to 5 1/4" may be the max. back spacing. But this depends on how the rear fiberglass tub was placed as the front inner side wall of the tire my rub the panel behind the seat. I had to cut the fiberglass and move it in to keep from rubbing occasionally. Honestly I would go 275 tires and narrower rims If I was to do it again. For me I like the tires in a little.
For the front I have the narrower tubular arms with 7" rims, 235 tires, and 4 1/2" back spacing. I think this works out good. The outside tire bulge is flush with the fender lip. I do not know the length of the A arms.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
