Old 04-12-2014, 08:20 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Default Location of Fuel Pressure Regulator
I am having problems with too high of fuel pressure with my mechanical pump. My options are either buy an Edelbrock pump that is set at 6 lbs. max or add a fuel pressure regulator.
For those with a B&B, if you have a regulator with a mechanical pump where did you locate the regulator. Pictures would be nice.
Thanks.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
