Long story guys that started with my wide band 02 sensor. Man I want to tell this story but just don't have the time to write it now. In summary went through three pumps, all claimed a max of 6.5 lbs. When I installed them and checked the pressure they were 8 lbs. I learned always check the manufacturers website to confirm the max pressure no matter what the retailer advertises. I found one brand that has a consistent problem with the pressure being 1.5 lbs. more that their specs say. I have been on the phone with their tech support and they are concerned. Seems to be a production problem.
So, I installed an new quick fuel carb last night and they set the floats up with 6.5 lbs. and run it on an engine before shipping. I put on another new fuel pump that said 6.5 max pressure and checked it when started with two gauges. It was 8 lbs. Float level was way high. Seems the only solution is to put on a regulator.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
