Old 04-13-2014, 08:06 AM
NeilsenRM NeilsenRM is offline
Default Independant Rear Suspension
I have read some articles about installing a Mustang Cobra independant rear suspension in place of the standard Ford 8.8 straight axle. The articles seemed to say that the Mustang Cobra IRS subframe/carrier would bolt to the same mounts as the standard rear end. It seems like the only modification might be a drive shaft length adjustment and a different differential spline to drive shaft adapter. I also see a couple of brackets on the IRS subframe that might need to be bolted to the car frame
My question is has anyone done this on their CR Cobra? Is it that easy?
Thanks
Rick Neilsen
Early CR with 302 5 speed
