04-13-2014, 08:29 PM
Vic
Did a very quick bit of research and can't see too much difference between the battery options between brands. Know I could get even higher cold crank output optionsand know the Odessey will work in any orientation but I need to fit the space in the boot I'd already set up to.
Both are good quality options so am going to stick with the Oddity as the same replacement type will just slot back in to what I have set up for. And importantly a supplier operates very near by that sells at a price ($317) I haven't seen as low anywhere else.
Can anyone help with advice on my question two posts back about checking the cam sensor set up??
Cheers guys
Slo
slowy
