Originally Posted by DanEC
I checked power from the turn signal switch going to the trailer relay (connection 70/71). When the left turn signal is on I get a blinking test light at the connection. On the right turn signal I get a steady, but low level glow. What ever that might signify.
I will switch front signal light bulbs and see if anything changes.
I would pull the two fast blow fuses out, and thus isolate the load from the relay, and then repeat that same test. See if you get a nice clean 12v going in to the trailer relay. Assuming yeou do then leave the fuses out and use a jumper wire to provide 12v to the "tail light" side of the empty fuse holder. See if your lights just come on at the back of the car doing that.
