04-14-2014, 01:37 PM
AR
Originally Posted by patrickt
Maybe the turn signal is misbehaving. Disconnect it at 71/72 and use a jumper wire to feed 12v first to the Green wire, then to the Yellow wire from that disconnected plug, and see if the four corner lights behave normally or not.
I don't think so Patrick because of post #7 above. When I switched the leads from the switch I still had left turn signals when I signaled right. I give up for today.
