Old 04-15-2014, 05:52 AM
blykins blykins is offline
Originally Posted by Texasdoc View Post
Any recommendations or comments on intakes for a 408? I would like to keep it street drivable without having to keep it above 4000k to get any power. I understand that the stroker kit will give me more power down low. But I'm not sure what else to look for.
The cam I'm considering is:
Hydraulic roller
Advertised Duration: 280/288
Duration at 050: 228/236
Lift: .565/.565
LSA/ICL: 112/106
I can barely squeeze the Airgap under my hood but have to use a 1inch tall 11 inch diameter air cleaner. I'm not sure if that is enough flow for the 408. So I am considering going with a different (shorter) intake. Performer RPM, Weiand Stealth? The Vic Jr is a single plane which I've heard are less tolerant on the street.
Any comments?
Didn't I recommend a cam for you? Unless you want a pickup truck hp and torque curve, the duration is too short on that cam, and I would run more lift.
Rpm air gap or victor jr either one would work just fine.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
