Originally Posted by Texasdoc
I don't even know what that means...
Thanks, tho. I talked to a few builders and custom cam manufacturers. They thought this cam would make the engine a little more street friendly. I can always change it later if needed. I'll go with the AirGap since I know it fits.
I'll call you when I'm ready for the AFR heads. It will likely be a few months.
It means that the engine would be more suitable for a truck with that cam.
You can not read or listen to the advice that a cam manufacturer gives you about a camshaft. I promise that I've built more 408 Windsors than any cam hotline operator.
I'm sorry for sounding a little crass, but I'm coming off of a weekend blessed with a stomach virus, so I'm not in the best of moods.
Anyway, I've built a whole lot of 408's, from pickup truck engines to race engines. The cam that you picked is way short on duration, and will probably peak somewhere around 4800-5000 rpm.
If that's what you want, then that's great, but IMO a performance engine should not be that short winded (but does not have to be radical either).
The last 408W that I did used a set of Trick Flow 11R heads, a Victor Jr. intake and a cam with about 12° more duration. It peaked at 5600 rpm, had a very flat torque curve, but still sounded and performed nicely, making about 510 hp.
I also built a 408W using a similar cam to the one you picked, for a guy's pickup truck that he was using to tow a car hauler. It peaked at about 4800 and made about 390 hp.
The biggest mistake that people make when searching for cams is that they read the description under the cam specs, "Power range from x rpm to x rpm". That may be true, but it's only true for one specific engine size, and it's usually the smallest size in the engine family. What they don't tell you is that a 408 needs a LOT more cam than a 351, and that even changes depending on the cylinder head and other parts of the build.
