Hi Kevin - this stuff is also pretty good although a little pricey.
Cleartastic Corvette & Camaro Paint Protection 1800 778 9898
I covered my rocker panels, lower part of rear fender flares and the roll under behind the rear tires with it. I also used it to cover the aluminum threshold and door jamb area below that. It comes in 6 inch and 12 inch widths and is pretty easy to cut with an xacto knife and apply with water amended with a little dishwashing soap. The adhesive sticks it down well but it's made to peel off without much effort (a heat gun would problably make it even easier). It's very similar to the XPEL stuff that I have used before (which is excellent by the way). It would not be suitable for the nose area since it doesn't come in large enough sheets and at least I don't have the skills to fit it to complex curves.
Just another option for do-it-yourselfers wanting to apply a little protection on some of the more straightforward areas.
