Originally Posted by Texasdoc
I don't even know what that means...
Thanks, tho. I talked to a few builders and custom cam manufacturers. They thought this cam would make the engine a little more street friendly. I can always change it later if needed. I'll go with the AirGap since I know it fits.
I'll call you when I'm ready for the AFR heads. It will likely be a few months.
You can use more duration with that 112 lobe separation and not sacrifice driveability. Something in the 235/245 range would be about right.
Also, that manifold will give you a better average horsepower, but you will sacrifice peak horsepower.
The last Engine Masters we did with a 408 we got 635 average with a dual plane, and 690 with a single plane. But, since we were racing dynos, after all......
