Old 04-20-2014, 01:53 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Thanks Patrickt.
I am trying to figure out the cause. Is it possible that there is just enough play in frame / bolt holes that the starter is vibrating loose.I am not sure how to cure my issue unless it is exactly as I said, (i.e the old starter damaged the flywheel and the flywheel then damaged the new starter.
Pictures should be uploaded.
Phil
