Old 04-21-2014, 11:35 PM
tkb289 tkb289 is offline
MCD …
My only suggestion is to gather as much documentation you can (from the suggestions above) to make your case and print it out, and be sure to site the sources.
The challenge will be to present this as diplomatically as possible to the inspector, so he can come to the conclusion, that indeed the numbers on your motor have not been altered. If the documentation is clear, the numbers on the block will speak for themselves. If you can, mark up the information you have that illustrates your point and let him keep it. Should work for you and maybe help the next guy.
If that does not work, then go to plan B.
Best of luck.
