  #26 (permalink)
Old 04-22-2014, 05:49 PM
DanEC's Avatar
DanEC DanEC is offline
I think it's more complicated than that. With the turn signal on and no braking, the only load is from the blinker element in the one bulb, plus what ever load contribution backfeeds from the front blinker element through the turn signal switch, plus the flasher unit.
While the flasher and front turn signal functions on a left signal, it's not functioning on a right signal - something is different on the right signal circuit versus the left one. I need to go back through all the connections on the right front parking/signal light and see if there is some reason for this. There is enough load to operate the flasher on the left side but not on the right side.
I also installed the panel over the master cylinders a couple months ago and wonder if I might have pinched a wire from the brake light circuit down there.
By the time I get this figured out I'm going to miss the spring season.
