Originally Posted by patrickt
And when I say "flatten the existing filter base" I am referring to the outside circumference of the existing base. You make small peripheral cuts, on the outside lip, maybe about a half inch between each cut, then just flatten it out. Like this:
Is this the base of the S&H? I wonder if it will fit my turkey pan unless these are all the same size because the S&H is 8 1/2 " in diam.
Lou
