Old 04-30-2014, 07:38 AM
Rick Parker's Avatar
Jon: Just a thought a little out of the box....With the carbs syncd and idle set. How far do you you have each idle mixture screw open? And can you kill each cylinder by screwing each one closed indepedently? If there are cylinders that dont respond to the idle mixture screw it's possible the port is plugged or the edge of the throttle plate is not exposing the port to manifold vacuum. Id be using a 100 idle holder and a 60 or 65 jet.
Shouldn't require more than that. Also what are you cam specs.
Rick
