Originally Posted by Blas
IF you send me your email offline, I will send you a few service Bulletins that will be of interest. Door adjustments, is among them.
Depending on how far off you steering wheel is it could just be the mounting screws off by one hole.
Blas
PM sent. Thanks. I took off the large nut on the wheel. Just pulled it and went 2 notches to the left. Tightened it back up. It feels pretty tight. I didn't feel like there was a certain way it has to go on like my Camaro. It had 1 big notch and could only go on one way.
I adjusted the door. All good
Speedo I took out of the dash. I couldn't remove the 90*, but wouldn't turn when it was connected to the cable. I put a small screw driver to turn the speedo when i disconnected it and quick bursts it moved. Couldn't check the cable
If I need a speedometer reverser what one do I need? I see Autometer sells them. Is this one correct?
http://www.summitracing.com/parts/atm-990340/overview/
