Originally Posted by gsharapa
Car runs great Bruce. I remember a couple years ago you had a thread with a lot of changes you made and you went with EFI throttle body and was wondering what you ended up putting on it as I love the response in and out of the tight turns?
Thanks Gary, it is a 1650 CFM Wilson throttle body with Fast EFI running in Alpha N mode. Injectors are 65 lb per hour, the response is something else when you consider that is a 3:31 rear end with a 2.1 low gear ratio so it is down around 2500 sometimes and still snaps to when asked.
