  #70 (permalink)
Old 05-04-2014, 01:01 PM
hercf16's Avatar
hercf16 hercf16 is offline
Originally Posted by Dimis View Post
Herc,
A couple of things.
1. A New paint job isn't that expensive. Body work is mostly done so labour costs aren't as high as they otherwise could be. Perhaps broaden your search with his in mind.
2. SPFs are great, and while you can put anything in them, making for a great cobra. They do recommend going SBF.
3. ERA arguably the gold standard in fibre glass cobras. So if you were set on an FE, then perhaps investigate this option also.
4. If you are having an custom engine built and wanted a boutique, non-cookie-cutter engine, you'd be hard pressed to go past Brent (George Anderson, Barry R, others can add to this list).
5. If buying an FE built by KC, You'd be wise to double check the build isn't using an eagle crank, they are offered as standard equipment in KC builds (see their website). There's documented history of them failing.
I hope that helps. Enjoy your hunt.
It's all part of the fun.
Thanks for the input. I have been looking at Superformance for years, I like
factory built roller idea and components but one of the biggest reasons is the
leg room in a Superformance compared to the others.
Herc
Herc
