Old 05-05-2014, 11:03 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Problem with using this type 2x4 manifold with side ways mounted carbs is that all your primaries will be feeding predominately into just 4 cylinders----
If you are into fabbing up something you can gut out the center between all 8 holes and fab up a riser to the top your planning on using------------
