Thread: Changing wheels
Old 05-15-2014, 10:12 AM
Dirkdaddy Dirkdaddy is offline
Cobra Make, Engine: West Coast Cobra 2007, 460 manual trans
I think you maybe confusing the diameter of the wheel/tire with width and offset/backspacing. A 17" wheel with lower aspect ratio tire can be the same diameter as the 15" wheel. If its sticking out the side, then its either wider, or you have the offset/backspacing off for what would be optimal. A skilled wheel shop can measure your exact configuration and suggest a wheel that would work well. and/or hopefully someone will chime in with a similar model.
Originally Posted by box710 View Post
My question is does any one know the size wheel that belongs on the front be it 15 pr 17 inch. We beefed up the suspension in the front and made adjustments in the fender wells to accommodate the 17s. I guess it has a lot to do with backspace. Just seeing if anyone owns one of these and knows the right size. Thanks in advance
