Originally Posted by ERA Chas
Those spun bases are the t!ts.
Neatly done. I got around that by flanging (like a bellmouth) the flat pan to the 5 1/8" Holley throats. Raises the plate to just rest on the adjuster nuts. Seals the pan completely to the throats.
My elements are RTV'd to the base and when the tops are unscrewed, just lifting the pan off brings the elements with it-simple.
I made the center studs with aluminum tubing so the tube acts as a stop when tightening the wingnuts on top. Had to play some to get just the right height for tension.
I have so little vertical clearance that I was forced to position the base plate as shown. Another less sightly option required a 10# sledge hammer.
David
