It may be disconnected now.. Mechanically blocked.. Be happy.. But be sure the mechanical advance is doing its job, and had a respectable curve dialed in for your Cobra... Most find a steep curve works pretty well without detonation. I get 38 degrees by 2300 rpm with my 428. I think your 351 can use more.. maybe 40?? but verify that with a small block guy before you do it... start at 10-12 degrees initial and you should have no problem. Good luck.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
