Bobcowan and Jim are correct, but Jim was more articulate on the reason. I made the same mistake last year after degreeing in many cams over the years. I was helping a friend with his Shelby big bore aluminum block and the cam measured way off. I checked and re-checked everything three times and could not figure it out. This was a Thursday night so somewhat embarrassed I said let's try it again Saturday. When I was laying in bed that night it dawned on me. I have special flat tappet lifters for Fords and Chevys I made 30 years ago that are 6" tall so I can put the dial indicator right on top without using a pushrod. I used one of these in his engine. Saturday we put in some solid rollers and it checked out within a degree.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
