Well..........Even the stock Ford brakes where deigned for a car much heavier than the Cobra.
Ventilated discs....like the Ford .plus a vacuum booster...(my booster and master cylinder from a Ford Tempo .are available at any parts store)........should be more than ample....unless you plan to hit the track every weekend....... I even have solid rotors and only had fade after a lot of hard driving and then only after it sits in the pit for a bit......a half lap of cooling and back to normal......
Also .....depends on your pocket ......
