Thread: Eight stack
Old 05-22-2014, 08:01 AM
Luce Luce is offline
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
Well, when I bought it, I knew there was a reasonable risk I was paying almost $1000 for a piece of wall art for the garage, but no. It looks good. I completely expect to need to sync the throttles and double check that the butterflys are properly staked, but they are all adjustable. I may wish to remake the center bellcrank and linkage out of aluminum when I finish my CNC router/mill, but that's more for appearance. The supplied steel one is tight, ridgid and symmetric so it will reliably open both banks in unison.
And no. All that this hardware does is restrict the air going into the engine. All that's critical is that all of the cylinders get the same air flow through their throttle bore and the manifold seals to the heads and block. The injectors and ECU handle the rest.
Too bad it'll be a few years before it's on a running engine.
