Old 05-25-2014, 11:08 PM
lippy lippy is offline
Patrick,
The play is mainly front to back but also side to side. The set screw and nut that holds the cylindrical sleeve to the splined shaft becomes a bit loose. That diagram is not exactly correct: the screw that holds the sleeve to the splined shaft sits on the splined shaft but does not go through it.
