Hi Dominik,
You will need to rework some of the 3/4 tubing in the rear, and a little bit of work on the cowl hoop ribs where the side exhaust runs under, but other than that, things will work nicely. I'm sure you've already factored in the fabrication work to support the body, so If your comfortable with that, I'm sure you'll have no problem. Which body are you going to use? The Coupe's have a 90" wheelbase, but you can trim the body or extend the frame to match your needs. You just want to be sure that at the end of the day.... It looks correct. Most coupe bodies do not use the original style glass, so you will need to get in touch with the body manufacturer to see which they recommend. The Jag glass will fit an FFR, the coupe and convertible glass are different, don't recall which they use. If you absolutely need original style glass, I may be able to get my hands on some. Shipping to Cape town ? ? ? That would be new to me. Good luck with your build. I will be starting on mine soon too : ) Chassis first !
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
