Originally Posted by Double Venom
I know it's good hard and earned money but Bob is so right . A good QA-1 shock like the DS-01 shock with 250 lb springs for the rears, and you will never have to worry about replacing them again.
DV
Does this 250 lb/in spring rate apply for coil overs mounted behind the axle (in the shock location)?
Also, does anyone know the rear axle weight and/or corner weights?
Thanks.
