Every engine combo will be a little different.....you just have to try different settings and see what works best for you combo....
My 331 stroker made the most power across the power band at a total timing of 30 degrees on the dyno.........with 22 degrees of advance,I set my initial/idle timing at 8 degrees and had the total timing all in by 2500 rpms....
I'd start at a total of 30 degrees and slowly work my way up,adding 2 degrees of timing at a time and see how things go.........
David
DAVID GAGNARD
