Originally Posted by ERA 778
Have you tracked down your taillight problem yet? I had a similar issue at debug and it turned out to be the taillight connection was shorting to the reflector or socket. Took a while to figure out since it only shorted out when I hit a bump or something so everything checked OK in the garage.
Yes, I did. It was a spade connector at the front turn signal lead that inexplicably came loose(?). Sometimes it's the simple things.
