Old 06-03-2014, 11:45 AM
strictlypersonl strictlypersonl is offline
I don't recommend elongating the inner lower control arm holes in the subframe. The brackets (that mount to the differential) are not meant to take significant side forces. They are there to secure the differential. If you really want to change the toe on the control arms, you are better off actually bending the arm by cutting the diagonals and re-welding.
