Old 06-07-2014, 10:20 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
I used a little hepa filter paper wrapped around the breather/tipover valve.......(you better have one on the breather)
there should be a little wire gauze filter in the tipover /breather ...wrap the whole valve with the hepa and use two of the very small zip ties ..... be sure not to block the little breather slot with the ties ....I mounted mine high in the wheelwell ...as close to the filler as posssible .
also aim the hole towards the center of the car....away from the wheel to minimize the dirt path....
