Thread: steering
Old 06-11-2014, 04:36 PM
FWB's Avatar
FWB FWB is offline
if your referring to the rack,...yes, Jag, plymouth omni, fox body t-bird
what crossmember do you have? if its set up for MII then that will be the easiest, and also lots of places make aftermarket parts for them.
the rack will attach via a rag joint and shaft, i don't think it'll care what column you have above it.
just be safe weld and pin the u-joints on the shaft.....
Fred B
