  #73 (permalink)
Old 06-13-2014, 08:44 AM
WHTNUKL's Avatar
WHTNUKL WHTNUKL is offline
Cobra Make, Engine: 1989 LA Exotics
Mine is a 1989 version of the B&B and came with sliding seats. However, I removed them and hard mounted the Kirky low back racing seats to floor. I would not recommend that for the street, but works GREAT for the track.
Putting in the aluminum radiator was one of the best mods I made to the engine compartment. I used B&B's, which are little pricey (sorry Brian) but fit and work well, simple bolt in. If you can weld aluminum, you can get a standard sized radiator from Summit or Jegs, fab your own brackets, and save $$$. I put in a high RPM, high CFM electric fan and haven't had a problem (except racing one day when it was 108 degrees in the shade).
"White Knuckle" rides require and "E" ticket, please.
